Alright, so I'm not sure if this is the right place on the forums to post this, but I am needing some help.
I am a part time Twitch streamer and I could use a little help with my settings on Streamlabs OBS.
Recently, I did a case swap and with that case swap, I also replaced my GTX 670 with a GTX Titan X(Maxwell).
Before the case swap, my stream ran decently with a few stutters here and there. After the case swap, however, my stream last night struggled to stay smooth.
I did up the graphics settings on the games I was playing(plus I was playing a game I hadn't streamed before(RE2 remake)), but I didn't think it would make the stream stutter so hard.
Could it now be that my cpu(i7-3570k oc'd at 4.2) was just struggling to keep up with the demands of streaming a newer game?
If that's the case, what should I do as far as my setting in SLOBS be? Or what should I be setting my games to for the least stuttering possible?
I do know that I need upgrade the CPU/ram/mobo, but that is only going to happen when ryzen 3000 comes out.
"Liam" - CPU: Ryzen 3700x Base GPU: EVGA Titan X(Maxwell) RAM: Trident Royal Z 32GB @ 3600mhz Case: Lian Li PC-O11 Dynamic White Cooler: Corsair H150i Pro RGB 360mm Case Fans: Thermaltake Riing 12 Series Whitex6
https://linustechtips.com/topic/1046072-twitch-stream-settings/
Just now, Electronics Wizardy said:
what is the cpu usage in game?
Id probably use nvenc for encoding, what encoder are you using now?
I am using NVENC.
As far as usage goes, I can't quite remember, but it didn't seem like it was getting over 40%.
https://linustechtips.com/topic/1046072-twitch-stream-settings/#findComment-12407089
Install Afterburner, enable OSD and all individual CPU-cores in the OSD, then look at their utilization without a stream running -- if any of your cores is at 80% or higher, then yes, you need to set SLOBS to use NVENC or you're gonna need to turn your settings down. Or upgrade your CPU.
https://linustechtips.com/topic/1046072-twitch-stream-settings/#findComment-12409993
30 minutes ago, wojtepanik said:
what res and bitrate you use on twitch?
I am outputting 720p and I had the bitrate at 6000 but I dropped it to 4000. That helped slightly.
SLOBS is already set to NVENC. I may just have to turn the settings down some more.
5 minutes ago, Theguywhobea said:
Does that model of Titan have NVENC? You could try streaming with that, or with QuickSync. You might take an image quality hit, but you should get better performance.
I think it has NVENC. I ran the "Stream Optimizer" tool that SLOBS has and tried to roll with those settings, but it gave me the stuttering.
https://linustechtips.com/topic/1046072-twitch-stream-settings/#findComment-12410071
37 minutes ago, LoGiCalDrm said:
What are your settings? Do you get issues in game or in stream (and if stream, preview or what comes out at Twitch)?
Bitrate I set to 4000, NVENC, I have a 200mbps connection.
The game isn't really having issues, it's just the stream. My viewers say that it's stuttering pretty bad as well. I could tell on the stream preview.
https://linustechtips.com/topic/1046072-twitch-stream-settings/#findComment-12410230
