Need help I have an MSI meg z390 ace lighting issues
I called MSI support because I had the same issue. These are the instructions they gave me and they worked! If you follow these instructions it should work for you.
1) Go to https://www.msi.com/index.php
2)In the upper right hand corner, click on the search icon.
3) Type "MEG Z390 ACE" and hit enter.
4)When the search results show up, click on "MEG Z390 ACE."
5) When the next page loads, you will see "MEG Z390 ACE" at the top of the screen in a red bar that runs across the screen.
6) In the red bar, on the right hand side, click on "support."
7) Now you will see 5 tabs: BIOS, Driver, Manual, Utility, and Quick Guide.
8 ) Click on "Utility."
9) In the drop down box, select your OS. In my case and probably most cases, it was "Win10 64."
10) Now, scroll down to "Dragon Center." On the right hand side, click on "Download."
11) Once downloaded, run "Dragon Center.exe"
12) Once you complete the installation, your system will reboot.
13) Once your system reboots, launch the Dragon Center app you just installed.
14) At the bottom of the Dragon Center app, you will see 4 icons. Click on the one that looks like a cloud with a down arrow.
15) Now click on the cloud icon that says "Scan."
16) When the scan completes you should see "MSI Utility." Under that you will see some options you can click.
17) Click on "MysticLight."
18) Click "Install" near the bottom right.
19) Dragon Center will update and relaunch.
20) When it relaunches, you will see a Mystic Light icon.
21) Click that and make your changes to your RGB! That's it!
