Thermal Paste
10 members have voted
  1. 1. Best thermal paste
    • ARCTIC SILVER 5
      4
    • NOCTUA NT-H1
      6
Just curious, which paste do you think is the best between those 2?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1035917-best-thermal-paste/
Just now, LukeSavenije said:
which?
i Edited it, sry.
Miss click
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319306
The Noctua. They're within each other's margin of error in terms of performance, as is virtually everything else between Chinese peanut butter in a jar and liquid metal on a bare die, but the AS5 has a lengthy burn-in and is slightly capacitive. If you squeeze it all over your motherboard and rub it in, it might short something. NT-H1 is not capacitive and won't have that problem.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319314
Really? wow...
So your saying Artic Sliver 5 is kinda like liquid metal stuff?
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319324
1 minute ago, Constantin said:
Really? wow...
No, not even close. Key word is "slightly" capacitive.
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319328
I have the Artic Silver 5 applied for about 3 months now.
I will apply the Noctua NT-H1 and let you know the results :)
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319332
Ohh, ok
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319333
1 minute ago, glenalz81 said:
Always used Arctic, never tried the Noctua stuff.
The only paste i use now is Gelid Extreme.
Is it the best you used so far?
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319345
Best standard paste is Thermal Grizzly Kryonaut. The difference between all decent to high end pastes is usually not more than 1-1.5°K ... basically irrelevant and within the margin of error of any benchmark. Liquid Metal might give you another 1-2°K improvement but that's about it. Toms Hardware made a bige comparison in 2017: Thermal Paste Comparison
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319371
Of those the Arctic Silver, but I'd take Kryonaut over either of those all day long
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319399
mx4 is better than as5, and kryonaut's the best paste i've used by a small margin, the premium for it isn't worth, go with mx4 imho.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1035917-best-thermal-paste/#findComment-12319719
