100v to 120v power?
Solved by Hackentosher,
Yeah it'll be fine. Most electromocs have a much higher mains input tolerance than you'd expect. Most electronics can allow a much lower voltage input than the sticker says, and the upper voltage limit is set by the caps inside the SMPS. Usually they're rated to 300-400v, but most electronics are designed to be used up to 240vac.
TLDR, a 10-20v increase almost certainly won't matter.
Featured Topics
Twiney_ ·
Posted in Troubleshooting0 -
mwthomas10 ·
Posted in Troubleshooting3 -
2
Nightmare-Rex ·
Posted in Windows3 -
13
4
Master_Kilvin ·
1
Foure ·
Posted in Networking2
