USB External Sound Card
Go to solution Solved by mr moose,
I guess you could try something like this, but I have no idea how it will sound.  I have one of those dongles you are talking about, It is cheap and the sound is fairly average. but I use it for a mame cabinet which is perfect.
http://www.ebay.com.au/itm/6-Channel-USB-5-1-External-Optical-Audio-Sound-Card-For-Laptop-Netbook-PC-/261089816735?pt=AU_Laptop_Accessories&hash=item3cca2a709f
I'm looking for a mediocre quality external sound card.
  • It doesn't have to have headphone amplification
  • It does not have to be audiophile grade
  • It must be obtainable in the UK
  • It must be cheap (£20 approx)
  • It must be a USB one
  • It must not be one of those plug in ones that look like this:
Are there any on the market right now?
Compatible with Windows 95
https://linustechtips.com/topic/103136-usb-external-sound-card/
I know of the Xonar U3.
http://www.amazon.co.uk/s/ref=nb_sb_noss_1/280-7991901-3882852?url=search-alias%3Daps&field-keywords=xonar%20u3
Bit out of budget, but nice deal nonetheless! I think Linus did a video on it once.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1379745
If you wanted to spend a bit more, you could maybe get a Fiio E10 but I'm not sure how much they go for in the UK, in AUS you can pick one up for $75 so they are probably around 50 pounds.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1379835
Fiio makes some really nice ones :-) also they are pretty cheap
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1380389
Xonar U3 might be the best out of all the bad solutions close to that price. I don't know of anything cheaper than that other than one of those bad syba ones. I tried the U3 and then returned it for a Fiio E10 because it just had so much static. The noise floor was pretty high and extremely noticeable.
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1380610
May even be able to change out the MB ,& do you have the drivers installed for MB - Audio ?
just a thought .
Case: | TT Core x71 | Mobo: | Gigabyte Aorus Elite DDR4 | Cpu: 13600K | 1.300V | P-Core 5.6GHZ | E-Core 3.9GHZ | Cpu Block: EK Quantum Velocity2 | Ram: Team T-Force Vulcan Z 4x8GB 3200MHz DDR4 | Gpu: Gigabyte GTX G1 970 Bios Hacked 1.275V | Gpu Block: EK | Cooling: Custom Loop | Rads: 4 | PSU: Corsair RM 1000w
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1381378
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1381474
I thought most realtek worked on hackintoshes.(alc888 worked fine on my hackintosh)
not sure on via chips.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/103136-usb-external-sound-card/#findComment-1382775
