I will be putting my PC together probably end of next week and was wondering if I should replace the pre-installed thermal compound that is on a H100i ?  If so what is a really good thermal compound to replace it with ?
Corsair 350D + AF Quiet Edition | Asus VI Gene ROG | 4770K OC 4.6ghz | H100i + SP Quiet Edition | 16gb DDR3 1866 Dominator Platinum | EVGA GTX 780 Ti OC | Corsair AX860 | 840 Evo SSD x2, WD Scorpio Black | Asus VG248QE + G-Sync | Ducky Shine 3 | DeathAdder 2013
https://linustechtips.com/topic/103029-h100i-thermal-compound/
no, just use it...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/103029-h100i-thermal-compound/#findComment-1378070
The last build I had it on was a 4670k and it idled at 20-22c and under full load was 38-42c so it works great.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/103029-h100i-thermal-compound/#findComment-1378087
It worked very well for me first installation with the pre-applied TIM.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/103029-h100i-thermal-compound/#findComment-1378101
