Fast AF Networking Not Need Just Because
On 2/4/2019 at 5:38 AM, Mikensan said:ZFS is not designed for speed by any stretch of the imagination. They have workarounds to help with speed, but their focus is data integrity. I would reflash your HBA, throw in a BBU and some RAM, and use it for RAID if you want speed.
Well right off the bat your HBA is probably plugged into a x4 slot (or will be if you buy an infiniband) which means you're capped out around 8Gbt/s. So no configuration of disks (even with an SSD on the SATA 2 port on your motherboard) is going to break 10Gbit/s.
Your next solution as already mentioned would be RAM disks. You may want to do some performance tests, as I "feel" like you might not hit 40gbit/s with DDR2 / your CPU.
Final note is SMB - it is horrible. It will definitely put some strain on your CPU which is already choking. It's certainly a very supported protocol, but it is not easy on your CPU.
*not trying to be a debbie downer, just hoping you don't buy these infiniband cards only to see 0 gain.
Thanks I thought the CPU and Board might be the problem. Strong for a 1080p plex server but not high speed file transfers or 4k video. End goal to switch to a 1st gen TR now that the prices are falling massively. (50% of retail). Which 32 cores at 4,0GHz will handle no problem. Mean time found some compatible ram on ebay for now going to go from 28g to 64g for $16 no real risk.
Side note no kernel panics on 1g but only on 10 gig for now which does sound like a ram issue.
