Where are you shopping / located?
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241639
Arctic Esports. Don't buy the 212 evo, its easily beat by coolers of the same price.
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241641
212 Evo is too expensive these days, $25 with a rebate only and that's still more than it's really worth.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241642
2 minutes ago, Vibora said:
Hey, I'm building an i7 8700, on an ATX motherboard in a Phanteks P400S case.
I've been thinking about Cooler Master Hyper 212 EVO or Raijintek Aidos.
Any suggestions for maybe better coolers not more than 40$?
i recommend the black edition of the hyper 212 since the it looks great and you dont need any more than that for ur cpu
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241646
Deepcool Gammaxx 400 is cheaper than the Hyper 212 evo and equally performing (more max performance while making more noise), I'd go for that if you're on a budget. Admittedly has no improvement in the looks category though.
Desktop benching:
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241704
Amazon.com
Why would you recommend it? Any specific reasons?
I see..
Mhm.
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241739
5 minutes ago, Vibora said:
Amazon.com
The Themis is a bit better and cheaper than the Aidos on Amazon and should be plenty for cooling: https://www.amazon.com/RAIJINTEK-Themis-Black-Cooler-Socket/dp/B00QMZIUFY/ref=sr_1_33?s=pc&ie=UTF8&qid=1548708681&sr=1-33&keywords=120mm+cooler
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12241905
7 hours ago, WoodenMarker said:
So you would suggest the Themis over DeepCooling and Arctic eSports?
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12243211
The Gammaxx 400 and eSports ONE are better but not as cheap.
Any of them would keep the 8700 temps in check so there's not much point in spending more for performance unless you plan to reuse the cooler for a different platform / cpu and want to oc. If you even up deciding on wanting something quieter, you can replace the fan later down the road.
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12248348
My 8700 is overclocked at 4.45ghz all cores with a 212X and it stays under 65Cº during full stressing while being virtually silent.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12248359
I totally thought OP had an unlocked chip, that checks out then.
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12248667
Just edited the main post, mind giving me your opinion?
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12254267
I already did.
If you're only interested in the eSports ONE or Pure Rock, they don't perform much better than the Themis but the Pure Rock is quieter. As mentioned, the fan on the Themis is easily replaced so there isn't much point in not getting it.
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12255629
2 hours ago, WoodenMarker said:
I already did.
Aight, Ill be taking the Themis.
Thanks for the help!
https://linustechtips.com/topic/1026961-i7-8700-cooling/#findComment-12256081
