Motherboard as a bottleneck - uncle needs help
Solved by Mira Yurizaki,
The motherboard uses PCIe 2.0, which may be an issue if not for the fact that it's effectively the same as PCIe 3.0 x8. And even the RTX 2080 Ti doesn't have issues with that speed: https://www.techpowerup.com/reviews/NVIDIA/GeForce_RTX_2080_Ti_PCI-Express_Scaling/
So you're fine. Especially for a GPU of that performance.
HyperPro_Andrew118 ·
Posted in Graphics Cards1 -
tanjackson ·
Posted in New Builds and Planning3 -
7
rich_az ·
proxyyfps ·
Posted in Troubleshooting2 -
Krisp-kiwi ·
Posted in New Builds and Planning14 -
3
3
Artur Hawkwing ·
Posted in Storage Devices8
