Need Help New Build Won't Post
Go to solution Solved by mxk,
5 minutes ago, Turtle Rig said:
Do you get any red lights on the motherboard upon bootup.  You should be recieving some kind of error code via digital or beeps.
don't the beeps come when you wire speakers a specific way?
Please Need Help New Build Won't Post
Asus X370 Crosshair Vi Motherboard
Ryzen 7 2700x
2x16 gb Corsair Dominator 3000Mhz
EVGA GTX 1060
Corsair CX650M Power Supply
Everything powers up but won't post and has had post codes: 0d,06,03,OE
The QLED Turns To green
Things I Have Done To Try And Fix It: Checked All The Wires Going To Everything, Took One Ram Out, Tested GPU In Another PC Works Fine, SSD in Different Sata Ports
https://linustechtips.com/topic/1024015-need-help-new-build-wont-post/
You are saying that you took one ram stick out.  Did you try it with only the one you took out too?
Just so other people dont have to look for it
0d - Reserved for future AMI SEC error codes
06 - Microcode loading
03 - System agent initialization before microcode loading
OE - Microcode not found
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
yea took one ram out and left one in and tried that still only goes to 03,0d or 06 postcode
it does not beep but has the QLED Lights and during start up it goes red then to yellow to red then green and stays green
in the manual it says (yellow)DRAM,(red)CPU,(white)VGA,(green)Boot
Check in the manual what that error code means.  Let us then take it from there.
