I bought this block used and and it was seeping for 3 months. I cleaned the block and it started leaking worse. I am just wondering if there is a way to repair it. It was modified by previous owner for hd 7950. (I know water cooling is not necessary, but it makes it quiet.)
VID-AR797 Water Block (AMD Radeon HD 7970 Video Card)
https://linustechtips.com/topic/1018920-help-with-leaking-gpu-waterblock/
I'd just get a new block.
There's a much less lower risk of damage to components down that road as opposed to trying to repair it.
Where's the oring ?
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Not really surprised it's leaking.
Doesn't appear to have an O-ring.
I just realized I omitted the o-ring I do have it and was not the problem. There are grooves in the metal.
Thank you to everyone who replied.
