Sata cable won’t fit | Corsair H500i
Celuta
So my sata cable from my built in control hub and case fan wont fit to the sata power for the on the power supply this is so frustrating someone please help
What case and power supply do you have?
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
I assume you have an NZXT H500 and a Corsair PSU? Corsair doesnt make the H500i case.
You shouldnt have any issue connecting the SATA  power cable from the controller into the SATA power connector into the PSU. It might be a tight fit, make sure the little L end piece on the inside is facing the correct way for both polugs
Image result for sata power connector
Image result for sata power connector male
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
