Freesync Monitor Paired with nvidia GPU
Solved by TMobile,
7 minutes ago, Imagine-Wagons said:Hello everybody so i'm looking to buy a new monitor because im playing on a tv right now and i was looking at the MSI Optix MAG241C but i noticed it has Freesync and not g-sync i've also noticed g-sync is way more expensive and i just wanted to know if you could still get the 144hz out of that screen while i have a nvidia GPU. thanks already
Yes, you can go 144hz, however you cannot sync the refresh time of the monitor woth the fps of your gpu.
