Low power consumption high performance ESXI server
Hi all. I'm planning a new build to update my old home ESXI system with something much better.
My current system is:
  • quad-core Q6600
  • 4gb of DDR2 ram
  • 1TB SATA HD
  • 2 Intel 1Gbit nics
  • An old Nvidia card
This thing is eating power, 140w of power and it feels like this is at idle as the two running hosts are not doing much.
The new spec I am aiming for:
  • 6 - 8 cores minimum
  • 16 - 32gb of ram
  • 1 - 2 NVMe M.2 drives 256GB is loads of space
  • Onboard simple graphics
  • out of band KVM management over IP
  • 2 x 10Gbit nics
  • 1 x PCI slot
  • Case, mini-ITX size 1u rack
  • Cooling, Passive if possible and fanless
I don't want much do I
What I have learnt so far:
  • An Intel i7 7740x or an AMD Ryzen 1700x could be good options for a processor. Is an Atom C3758 a bad idea
  • I should look at an 80 Plus gold or better PSU
  • SSD's will greatly help my Power consumption targets
I'm kind of looking for a lower cost more mainstream, better ESXI supported Supermicro A2SDi-H-TP4F or Gigabyte MA10-ST0.
Apart from the cost and the processor type these board ticks all the boxes.
My questions:
  • Which processor should I be looking for? I'm looking for a high core count with hypervisor support that is very power efficient
  • Once the CPU is selected we can look for a motherboard but do we have any combinations known to be low power high performance
  • Is there a system builder who specialises in low power high-performance systems
  • Does anyone know of a specialist website where low power high performance is their game?
Any support here is well received, this should be a fun build.
So team, what do we think?
Thanks
You don't always have to go with special "ESXi support confirmed" boards.
For example, my ESXi Host has got a simple Asrock H110M-ITX.
But that's not a board suited for your requirements.
Main PC: R7 3700X / Gigabyte X570 I Aorus Pro Wifi / Radeon RX 5700 XT / 32GB DDR4-3200 / 250GB & 2TB Crucial MX500 (in HP Prodesk 400 Case)
Laptop: R5 2500U / Radeon Vega 8 / 8GB DDR4-2400 / 500GB SK Hynix BC501 (HP Envy x360 13)
My little Server: i7-7700 / Asrock H110M-ITX / 24GB DDR4-2400 / Samsung 860 Pro 250GB & Seagate Firecuda 2TB / VMware ESXi 6.7
(Don't tell me i should Name them, i don't want to ^^)
Well AMD won't be an option for you in that case.
They need a dGPU because they don't have an iGPU and you need the PCI-E slot for a 10Gb ethernet adapter if you stick with mini-itx.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Some of the mini-AX boards I have seen have 2 x SFP sockets on them which is super nice, they just are getting expensive.
Just seen the Gigabyte MB10-DS4 which has all the ports ect and a Xeon D processor but it's $1k
Yikes!
So actually this Supermicro server is almost it
5018D-FN4T
Anyone seen a similar spec server that's a bit quieter and less than $1k?
Thanks
What are you doing with the ESXi server? I can make better suggestions hardware-wise is I knew what kind of load to expect and where to focus resources.
-KuJoe
It will be running a few instances of centos, Web servers, Asterisk and a couple instances of windows.
Typically I use the system for testing my builds and thus I don't need a lot of storage but when I am using it I want it to run fast so I can build fast and start running tests
you can probably get away with a bit slower of a cpu, and a fast atom based c chip here if you want to save a buck.
But if you want fast and low power, your spending a lot of money as you need basically new hardware for this, esp if you want it server grade.
Going with a ryzen can save you money if you don't need a server board(no sfp+ or impi or ddr4r support)
If he only needs 6-8 cores then why not an AMD? he could use a Ryzen 5 2400G which has iGPU.
It wouldn't however have IPMI management (which i assume is what he means by KVM over IP?). Personally I find IPMI useless in a home environment after I setup my server.
Be extremely hard pressed to find anything that comes with a PCI slot from this decade though....can get PCI-E x1 to PCI adapters though
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO | 12 x 8TB HGST Ultrastar He10 (WD Whitelabel) | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
The 2400G is only 4 cores, it has HT which helps but that's imo not good enough.
I would just run it headless (don't really see the need of a GPU) once it is configured but that might be just me?
Like, it has onboard ethernet, that can be used to manage it and use the other 2 ethernet ports for actual data transfer.
PCI-e is probably what I meant, I'm a bit behind in the hardware game.
Some of the gigabyte and Supermicro boards have a separate ethernet interface like an ilo and onboard simple graphics, so yes I plan to run this headless.
On the ryzen chip I'm seeing the previous gen is lower power consumption and I'm guessing a bit lighter on the pocket 1700x
Currently considering:
  • Gigabyte MB10-DS3 Server Motherboard
  • Supermicro SuperServer 5028D-TN4T Mini-Tower Server (Maybe quieter than the rack version below due to larger, slower running fans)
  • Supermicro 5018D-FN4T Barebone 1U Intel Xeon D-1541 8-Core System-on-Chip
The above are $$$ though
I think we are getting there though
Thanks all for the input, can't wait to make a decision and get the kit ordered. I have a 1Gbit internet connection to consume
