need help with 6pin and 8pin problem
Guest
I have an msi armoured rx 580 and it's the first graphics card/thing i've put in my pc (as i didn't build my pc), but when I put it in a few weeks ago I came across a problem with 6 and 8 pins as my old card (rx 470) had 6 pins, where as my new one had 8 (rx 580), so when I went to connect the pins there was only 6 and another 2 zip-tied off to the side, I didn't know what to do so I just put the 6pin into my 8pin, and it still worked. Is this meant to happen and/or should I go and take off the zip tie and connect the other 2 pins to create an 8 pin?
If the videocard has a 6+2 pin (8 pin) connector, you should connect a 6+2 pin (8 pin) cable to it if you have that available. If you don't have it available, you should consider upgrading the power supply.
If you don't plug in all the cables, you run the risk of getting an unstable GPU in heavy load situations (where the GPU needs extra power to run and it expects it is fully plugged i.. when it is not)
Yes, plug the 6+2 pin into the card.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
so should i go and attach the other two pins?
yes
Quote or Tag people so they know that you've replied.
Basically, yes.
3 minutes ago, Minibois said:
Basically, yes.
alright, cheers
