When I play games such as Battlefield V or GTA V I notice that my GPU only sits at around 80% utilization and my CPU doesn't ever exceed 60% usage. These low percentages result in me having an fps of about 30fps when it should be higher. I have monitored each of my i7 8700 cores and no cores ever exceed 60% usage too. The temperatures of both my GPU and CPU also don't ever rise above 65 degrees celcius. I am playing on an ultrawide resolution of 3440x1440p and don't have any form of v-sync on (I do have g-sync on though). I was wondering what could be causing this poor performance or whether it's just that my i7-8700 isn't powerful enough for my RTX 2080ti due to it not being overclocked. I have turboboost on and on my msi overlay it says the cpu is at 4200mhz. My specs are as follows:
intel i7-8700 (non K)
MSI RTX 2080ti gaming x trio
16gb of DDR4 2400mhz ram
Asus maximus x hero motherboard
EVGA 750w 80+ gold PSU
NZXT kraken x62
https://linustechtips.com/topic/1010938-low-cpu-and-gpu-usage-while-gaming/
CPU usage wont ever be totally used in most games, its just uncommon for them to ever do that. Most games will push a GPU to 60-95% utilization. Makes sure you arent frame capped, let it run unlimited and see if that fixes it, or remove settings.
NZXT kraken x62
the ram could be the problem here, got any 3200 mhz u can slap it, your entire build looks decent except for the ram.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I haven't got any better ram handy but i didn't realise ram speed could limit a system so much and lower fps
From my experience, on a single threaded game the newer cpu's swap around the load a lot so that it doesn't stay on one thread so having multiple on 60% might just be one thread going 100% effectively. Try limiting the game to one or a few threads (right click and set affinity in task manager in processes on the process) then you can see if you get about the same performance but a more true utilization.
easy test, u can lower it to 2133 to see if it gets even worse :), under 3000 u can start to slow ur cpu down imho, couple that with other conservative imc/bus settings on some motherboards and yikes.
You can also try to overclock it to 2666 to see if it helps, at least a bit.
2133 will make any pc seem like a piledriver.
If i limit it to 4 threads then 3 are around 70-80% and 1 is at 95-100% and my performance is the same as having all 6 threads.
setting ram to 2133 made maybe 2 fps lower if anything. I have seen in many other forums and side to side comparisons that claim that the difference between ram speed from 2400 to 3200 is negligible
2400 to 3200 is about a 5-10% difference in performance depending on the application, in gaming it affects 1% lows and average fps, i'm not saying it'll fix everything but upgrading to 3200, it's normal for a 6 core 12 cpu to not be at 100% while gaming, but it isn't normal for the gpu to be at 80% at 30fps. Something else is likely wrong here.
Ram speed is usually not an issue above a certain speed and is only really for min maxing (i get 5% more fps in some games going from 3200 to 4000), but 2400 is on the low side. Especially with your other components, it's not worth it cheaping out on the ram.
Edit: better video with an 8700k/1080 ti, look at how the lows take a 20% hit
If you have it limited to 4 threads and get one at around 95-100% I think you can be safe to assume that the game bottlenecks on that single thread and not anything else.
You can check around google if there is some tricks to lower the cpu usage of those games but they are of a few that are heavy on the cpu and as most games always bottleneck at one thread having the work the hardest even if they are well multi threaded.
tl:dr, yes your cpu is bottlenecking, only in these games though.
Thanks for the answer. I might then look into upgrading ram and maybe getting either an 8700k or a 9700k and overclock it.
