Need help with x79 LGA2011 motherboard, R/ECC ram, i7-4820k
Solved by Stefan Payne,
4 hours ago, COKATOLA said:The description said that the motherboard was only compatible with a REG/ECC ram
Yes maybe but the CPU does not. You need a Xeon with a Xeon Chipset (C602 or so) to use it.
You can't use Registred ECC RAM with a Core i7 CPU, even if the Motherboard allows it, its disabled in the CPU.
