Ideal CPU for gaming.
Solved by RogueLizard,
22 minutes ago, Islam Ghunym said:thx really but I want some information about how to pick the right processor, I mean what are the main specs in the processors that affect gaming experience, I know that all CPU specs are needed to be higher for better performance but there is always priorities for everything which what will answer my main question really.
thx.
cores and clock speed. Clock speed has a bigger effect on gaming. There are small increases in the amount of instructions a CPU can execute per clock with every generation.
Get an i5 8600K. Problem solved.
