Maybe you're using different settings, maybe it's a CPU heavy  game and he has a better CPU, maybe your PC is running way too hot, maybe you'r doing something else on your PC at the same time as gaming.. maybe you are running on a 150W PSU...
There are way too many variables to give you an answer to this... question?
https://linustechtips.com/topic/1007392-help/#findComment-12072098
Less FPS where? Which game(s)? Do your friends have faster CPUs by any chance?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1007392-help/#findComment-12072100
Better thread title please, seeing "Help!" makes me not want to help
You probably have a worse CPU than your friend.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1007392-help/#findComment-12072102
36 minutes ago, Tonmoy said:
i5-4570 + g1.sniper b5 + Galax exoc gtx 1050 ti and 8gb ram but Getting less FPS than friends using 1050!
There are a lot more factors we need to know here.
What are his specs? What game(s) are you talking about?
What settings are you using? What settings is he using? What is your Resolution? What is his Resolution?
How many Hz is your monitor and how many is his? Using Vsync?
Maybe consider finding a benchmark like Unigine heaven? Then running it on the same settings and comparing results.
https://linustechtips.com/topic/1007392-help/#findComment-12072236
1 minute ago, Tonmoy said:
suppose dota2, I got only 70 fps and my friend gets 240 fps
same setting.
And your friends PC has the same CPU, RAM etc?
You're sure your monitor is connected to the graphics card and not to your motherboard?
https://linustechtips.com/topic/1007392-help/#findComment-12080122
