Hey guys, I just upgraded to a 9700k, using a Notcua NH-D15S. Now, this thing had no problem keeping my 6800k under 45 when playing stuff like the Witcher 3... but now while playin Witcher 3 I'm up to the 60's.
I ran a cinebench multi core test and briefly hit 70 on one or two cores. Does this chip really just run that hot? Or should I start toying around in the UEFI and messing with vcore? If so, what should I do?
Maybe my thermal paste application wasn't great too?
https://linustechtips.com/topic/1003130-9700k-running-hot/
8 minutes ago, Weric said:
I mean you could try reapplying the thermal paste and all, but these processors indeed will run hotter than your broadwell-e would, they are using technology meant for just 4 cores like Ring Bus which to work with 8 cores now needs a lot of power and balancing every thing has been very complicated.
The stock turbo boost is extremely aggressive compared to what it used to be on broadwell days as well.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1003130-9700k-running-hot/#findComment-12033473
70C is nothing to write home about. If you're pushing 90, you have problems. Generally, anything a good margin lower than that is perfectly fine.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1003130-9700k-running-hot/#findComment-12033478
2 hours ago, Arika S said:
put it back to stock. there is nothing wrong with 70c on a CPU
I understand 70c is a safe temp it just seems a bit high for a stock cpu on an NH D15S running one round of cinebench. Hard to find a lot of user tests on the 9700k, no ones buying it cuz they have 8700ks. So, you would zay 70c on the noctua, stock clocks turbo up to 4.9 is normal? Im not used to hot cpu's honestlt, I went from a 3770k on a noctja U15S whicb was super easy to cool, to the Broadwell 6800k on an NH D15S which was also really easy to cool and NEVER reached even 55C. Heck on cinebench stock clocks it may have hit 42. Just nerve racking to see those tempz when Im used to much lower lol
https://linustechtips.com/topic/1003130-9700k-running-hot/#findComment-12034027
18 hours ago, Weric said:
Woops, 1.248, sorry.
Ok, thats reasonable. I was thinking it being over 1.27V to 1.34V what has been going on with 7700K and 8700K.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1003130-9700k-running-hot/#findComment-12049167
