So I bought myself an Hp pre-built desktop pc. When I finally got it I downloaded Overwatch and opened geforce exp. to fit the perfect settings for gpu. Than I downloaded precision x evga and realised that my gpu has 82C on those settings and I am worried if this will somehow damage or even destroy the card. Its a gpu blower type.
My PC parts are:
i7-8700
gtx 1070
16gb ram
https://linustechtips.com/topic/1001699-are-those-temps-ok/
It won’t destory it. Not by any means. But 99.9% of HP computers thermal throttle on the GPU because of that CRAP cooler they use.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021070
2 minutes ago, narrdarr said:
laptops normally run a bit warmer.
did you set a fan curve?
It’s a desktop per the OP
RIP
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021085
Can you get a custom prebuilt? @AshenFire and return the HP?
RIP
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021114
RIP
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021327
obviously the model with more ram (16gb vs 8gb) but same style?
RIP
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021330
RIP
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021337
Prebuilt desktops are pretty much crap when it comes to cooling and the GPU being a blowerstyle version is even more crap.
But the temps are perfectly fine for blowerstyler GPU's.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12021350
Turn up the fans. Fe1080’s can sit in the 60’s. 70’s with bad airflow.
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12023425
10 hours ago, AshenFire said:
and i thought about and i will probably buy myself a new case a new mobo and a better cpu cooler and power supply and use the cpu and gpu from this pc and build with that a new one
That case has absolutely poor airflow, so your components will run warmer, without a doubt.
...this is kind of expected for pre-built PCs...
To add, the blower / Founder's Edition cards do run hotter than an open cooler design GTX 1070.
Image result for GTX 1070 ASUS
You will need open up your computer case, and CHECK to see if you can even USE a new case.
With a lot of HP / Acer / DELL computers, they tend to use non-standard components (e.g. motherboard, power supply, etc).
If that applies to THIS computer, it won't be compatible with any of the ATX cases out in the market.
Looking at the back of the power supply, it doesn't look like to be the standard ATX form factor...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1001699-are-those-temps-ok/#findComment-12023555
