Is it hard to swap the cooler?
Hi P
I basically have all the parts needed to turn on my computer, but by doing so I would have use the Wraith Stealth Cooler included with the Ryzen 2600, my Dark Rock Pro 4 arrives in around 5 days or more I think.
Would it be hard go change the cooler once everything is assembled inside the case?
Thank you
Shouldnt be to hard but i wouldnt attempt it if u dont know what u r doing.
MAIN PC (Beast) - Asus ROG Crosshair Hero VII WIFI  with BIOS 4703, AMD Ryzen R9 3900XT + Corsair H115i Pro RGB XT Cooling, 32GB G.Skill 3200Mhz 16,18,18,38 1.35v DDR4, Inno3d HerculeZ Design Nvidia GTX 1080 X2 8GB GDDR5,  1 x Samsung U28E590D & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 3TB Seagate Barracuda SATA III, 1 x LG BH16NS40 16x BR\DVDRW, ICYBOX IB3740-C31 & ICYBOX IB3640-03,  MZHOU 7 Ports PCIe USB 3.0 Card, 1 x XIAOLO 2.5G Intel I225V Ethernet Card, 2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Corsair Obsidian 750D Wind Force Edition Case + 5 Corsair ML140 140mm Case Fans, EVGA 750 g3 750w Gold 80+ PSU, Logitech MX Vertical Mouse, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, Synology ds215j NAS + 1x3TB WD Reds connected to a 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
I don't, I think I will wait
I can confirm this. Don't mess around with computers without knowing what you're doing, bad things could happen. Look for tutorials online, I'll post some here soon.
if you find releasing 4 screws is difficult, don't do it.
he already build the computer him self i assumed.
I'm pretty sure @Hi P built it themselves, but installing aftermarket coolers (which are designed for many different types of socket) is harder than installing a stock cooler (which is designed exactly for that socket).
You will never learn if you do not try.
That being said. Just give it a go and be carefull! If you don't use force it will be hard to break anything ;)
The cooler will usually come with a installation guide.
You want to follow the guide for installing the cooler on "Socket AM4"
The cooler will likely come with some cooling paste.
Find on youtube a video about this cooling paste and how to apply it. or just use a small blob. don't over do it. (Less is more in general)
If you feel like your cooler is secured in place.
Start your computer and run temperature reading software to see the results.
Good luck :D
if you have access to the area behind the socket on the motherboard when you remove the rear panel then there should be no problem really
Builds:
12 minutes ago, 1kv said:
I'm pretty sure @Hi P built it themselves.
I haven't, but I do have the parts, I'm so scared of the assembly, lol
Good luck :D
Yeah, you won't learn unless you try...
I taught myself to build PC after i dismantle my very first pc and upgrade it piece by piece.
Before the age of internet, i have to literally buy a magazine to read a guide to install something.
Mistakes is your friend, learn from it.
Don't be scared or afraid. You have to do it to learn how to do it. Watch tutorials online, watch LTT build videos, do whatever you need to feel confident that you can build the PC.
Just don't stay with your hand holding the thermal paste tube right above your opened PC after applying it on your CPU, the paste trail may drop onto the wrong place of your motherboard like PCIe or RAM slot gap hole, you will get hard time cleaning it..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
The difficulty of installation depends on the cooler and socket.
Refer to the manual and videos.
