help me improve my Bitfenix Prodigy temps
Z Overlord
stock clocks, full load under LinX my cpu (i5 3570k) is about 67c. Seems kinda bad even if the prodigy isn't a super big case
aftermarket cooler: Dark Rock 2
Rear Exhaust fan: Noctua NF-P14 FLX 140mm Case fan
Front intake fan: BitFenix Spectre All Black 230mm Case Fan
I tried removing the front panel but it didn't do anything, my graphics card is a small HD7850. I think I did the thermal paste poorly (any tips on this?)
are these temps the norm for this? Do you think I'd be able to get a small/decent OC with it?
Temps are fine , you can OC till it hits 80 degrees. Actually the smaller the case , the higher the temps.
Interested in Business and Technology
try undervolting a bit
what cpu do you have?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
My overclocked fx 6300 hits 40c max
what cooler and ambient temps?
AAAAAAAAAGGGGGGGHHHHH!!!!
Get a better cooler if you want better temps.
Using the quiet cooler isn't helping it =/
You're looking at over a 10 degree change in just switching to a better cooler.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
is not the Dark Rock 2 a decent cooler?
it is, try remounting it
maybe its just a hot chip. unfortunately every cpu is different in some way or another. try buying an all in one water cooling unit if you have the money.
You could add 1-2 intakes either on top or change rear to intake and keep passive exhaust or exhaust from top. Better case cooling results ~5C lower temps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Entirely different architecture. The OP's i5 can run at substantially higher temperatures.
67C under load seems OK.
Oneplus 6 | Sony 55" X900F . Lenovo Y540 17" 144Hz RTX 2060 . i7 9750h.
Audio-GD DAC-19MK3 > Schiit Lyr 2 + > FOSTEX TH900 . Sony XBA-Z5
Tx3 push-pull
Tx3 push-pull
What i'm getting at is that you need context on what and how you are cooling. what is your OC and volts, whats the room temp? if there is no context, its a moot point.
My fx 9590 at stock stays under 50c at 20c room temp, cooled by a custom loop.
I got 100 C mate:/
67c is quite cold under load. you should overclock it so that its nearer 80c
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
room is 18.3333c. 1.415v................. 4.8ghz
