Posted June 27, 2017 The LG 34UC79G-B has freesync, 144hz, 1ms and but at 2560x1080. The Acer XR342CK also has freesync but has a 75hz and 5ms and resolution at 3440x1440. So the one with better HZ and MS or the one with better Resolution? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2017 what GPU will be driving this setup? Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+ Smallsnor: Huawei Matebook X Canon AE-1 w/ 50mm f/1.8 lens Pentax KM w/ 55mm f/1.8 SMC lens Zenit-E w/ 58mm f/2 Helios lens Panasonic G7 with 14-42mm f/3.5 lens Polaroid Spectra System Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2017 Samsung CF791 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2017 Author 34 minutes ago, shadowbyte said: what GPU will be driving this setup? Rx 580 gpu, Ryzen 7 1700x cpu, ASRock - X370 Taichi Motherboard Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2017 Response time is a useless metric that means basically nothing now. As @WereCat said, the Samsung CF791 is a good compromise between the two monitors. It's 1440p and 100hz. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
