PWM Chassi fans showing up as single fan (NA rpm) in BIOS
Solved by W-L,
11 hours ago, Sigge_Sandstrom said:So I´ve got 5 fans in my chassi all connected to the fan hub on the back off the motherboard tray. My chassi is a Enthoo Evolv mAtx.
But in BIOS the only fans that show up is the CPU fan, which shows rpm, and 1 CHA fan, which shows NA rpm.
My first question is: Does the motherboard see all the fans connected to the fan hub as 1 fan?
Secondly: Why could it be that it doesn´t show the rpm?
Thanks in advance!
Are you talking about this fan controller? If so it requires a PWM control from the motherboard to be on the input of the hub where it then provides an equivalent 3 pin DC voltage control to the fans. The fans will run as a group and show up as a single fan on the motherboard.
