[Build Log] Corsair 750D, Water Cooled, Project "Golden Night" [IN PROGRESS]
DeuS1
Hey Awesome people :)
I have now started building my "Golden Night" machine..
It's gonna be a Water cooled Corsair 750D with colour theme "black/gold"
This is my first ever watercooled build, so i'm very excited to get started with it :D
Here's a list of what i have so far for the build:
Hardware:
Case: Corsair Obsidian Series 750D
CPU: Intel Core I7 4770K 3.5GHZ 8MB Haswell
GPU: 2 x EVGA GeForce GTX 680 2048MB GDDR5
PSU: Corsair RM Series RM850 850W
Ram: Avexir Core Series GOLD - DDR3-1600, CL9 - 16 GB Kit
MOBO: ASUS Z87-PRO LGA 1150 Intel Z87
OS SSD: Samsung 840 EVO 120 GB
Backup SSD: Samsung 840 EVO 1000GB
Water cooling parts:
CPU: EK-Supremacy Clean CSQ - Acetal
GPU: 2 x EK-FC680 GTX+ - Acetal
GPU Backplate: 2 x EK-FC680 GTX Backplate CSQ -  I Am thinking of getting Custom backplates in black, with Nvidia Claw in gold, and gold writing "GTX 680" (work in progress)
Reservoir: EK-RES X3 250ml
Reservoir Top: EK-RES X3 - Multiport TOP
Pump: EK-D5 Vario X-TOP incl. Pump
Rads: Magicool Slim Profile 2X140mm + XSPC EX360 3x120mm
Fittings:
Monsoon Adapter 45 Grad 19/13mm - gold
Monsoon Adapter 45 Grad 19/13mm - black
Monsoon Adapter 90 Grad 19/13mm - gold
Monsoon Adapter 90 Grad 19/13mm - black
Monsoon Push On fitting 19/13mm - black
Monsoon Push On fitting 19/13mm - gold
Monsoon Light Port 45° Rotary Angle Fitting - black - for temperatur sensor
Monsoon Premium G 1/4 Temperatur Sensor - gold
Monsoon Standard Rotary Color Accent Disks - gold
Monsoon Standard Rotary Color Accent Disks - black
Modding:
Bitspower D5 / MCP655 Mod Kit - Gold Finish
2 x 12" cold catodes in yellow, with black sleeved cables
4 x BitFenix 6-Pin PCIe extension cable - sleeved Gold/Black
6 x BitFenix 3-Pin PCIe extension cable - sleeved Gold/Black
1 x BitFenix 24-Pin ATX extension cable - sleeved Gold/Black
2 x BitFenix SATA 3 extension cable - sleeved Gold/Black
Fans:
3 x Corsair Air Series AF120 Quiet Edition High Airflow 120mm Fan
3 x Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan
3 x Corsair Air Series SP120 Performance Edition High Airflow 120mm Fan (Still awaiting these to arive)
Lamptron FC Touch Fan Controller (Still awaiting this to arive)
So anyways, LETS GET STARTED !!! :D
I will update with images as the build comes together :)
post-78152-0-16043300-1398335388_thumb.jpost-78152-0-70841700-1398335394_thumb.jpost-78152-0-22403200-1398335402_thumb.jpost-78152-0-87234400-1398335408_thumb.jpost-78152-0-10152700-1398335420_thumb.jpost-78152-0-11086200-1398335427_thumb.jpost-78152-0-48753900-1398335432_thumb.jpost-78152-0-57445700-1398335440_thumb.jpost-78152-0-26506200-1398335489_thumb.jpost-78152-0-23734300-1398335496_thumb.jpost-78152-0-94476500-1398335502_thumb.jpost-78152-0-98759400-1398335507_thumb.jpost-78152-0-31104700-1398335515_thumb.jpost-78152-0-39343600-1398335521_thumb.jpost-78152-0-04104600-1398335527_thumb.jpost-78152-0-31710000-1398335532_thumb.jpost-78152-0-87019700-1398335568_thumb.jpost-78152-0-53435200-1398335574_thumb.jpost-78152-0-19381700-1398335581_thumb.jpost-78152-0-59062300-1398335586_thumb.jpost-78152-0-04365900-1398335593_thumb.jpost-78152-0-08931600-1398335599_thumb.jpost-78152-0-25584700-1398335604_thumb.jpost-78152-0-57316100-1398335608_thumb.jpost-78152-0-28357900-1398335628_thumb.jpost-78152-0-81389600-1398335632_thumb.jpost-78152-0-95491500-1398335638_thumb.jpost-78152-0-08394400-1398335644_thumb.jpost-78152-0-01081100-1398335652_thumb.jpost-78152-0-20498100-1398335657_thumb.jpost-78152-0-62402700-1398335660_thumb.jpost-78152-0-55055300-1398336256_thumb.jpost-78152-0-32842800-1398336262_thumb.j
this is what i have so far, will update with more later when i start building :)
Started modding,, NEW IMAGES! :D
post-78152-0-93562000-1398379019_thumb.jpost-78152-0-65292000-1398379026_thumb.jpost-78152-0-14993500-1398379038_thumb.jpost-78152-0-76389600-1398379044_thumb.jpost-78152-0-81086800-1398379058_thumb.jpost-78152-0-62152400-1398379068_thumb.jpost-78152-0-43072400-1398379085_thumb.jpost-78152-0-74132100-1398379097_thumb.jpost-78152-0-14478200-1398379107_thumb.jpost-78152-0-36298100-1398379288_thumb.jpost-78152-0-46883700-1398379302_thumb.jpost-78152-0-03847500-1398379311_thumb.jpost-78152-0-52347100-1398379323_thumb.jpost-78152-0-11341700-1398379347_thumb.jpost-78152-0-88936400-1398379356_thumb.jpost-78152-0-19478500-1398379371_thumb.jpost-78152-0-16973700-1398379364_thumb.jpost-78152-0-23175000-1398379378_thumb.jpost-78152-0-44825400-1398379556_thumb.jpost-78152-0-97498600-1398379562_thumb.jpost-78152-0-81343900-1398379571_thumb.jpost-78152-0-10787600-1398379579_thumb.jpost-78152-0-29685000-1398379586_thumb.jpost-78152-0-77380100-1398379593_thumb.jpost-78152-0-85394200-1398379599_thumb.jpost-78152-0-55812000-1398379612_thumb.jpost-78152-0-80962100-1398379621_thumb.jpost-78152-0-91760900-1398379633_thumb.jpost-78152-0-52397800-1398379762_thumb.jpost-78152-0-26068100-1398379769_thumb.jpost-78152-0-43418400-1398379774_thumb.jpost-78152-0-61904800-1398379781_thumb.jpost-78152-0-84997100-1398379830_thumb.jpost-78152-0-43499100-1398379836_thumb.jpost-78152-0-89295200-1398379842_thumb.jpost-78152-0-12751400-1398379853_thumb.jpost-78152-0-14035500-1398379860_thumb.jpost-78152-0-79481300-1398379867_thumb.jpost-78152-0-14739300-1398379877_thumb.jpost-78152-0-78739400-1398379888_thumb.jpost-78152-0-98611100-1398379898_thumb.jpost-78152-0-63231200-1398379908_thumb.jpost-78152-0-39025300-1398379990_thumb.j
DONE BUILDING <3<3<3<3
Here's the images of the last build process + images of the finished build <3
post-78152-0-00252000-1398859492_thumb.jpost-78152-0-03674000-1398859505_thumb.jpost-78152-0-36099900-1398859520_thumb.jpost-78152-0-76021000-1398859529_thumb.jpost-78152-0-19139900-1398859551_thumb.jpost-78152-0-48474700-1398859569_thumb.jpost-78152-0-53207000-1398859585_thumb.jpost-78152-0-10308700-1398859599_thumb.jpost-78152-0-47915700-1398859617_thumb.jpost-78152-0-26464100-1398859634_thumb.jpost-78152-0-33962100-1398859683_thumb.jpost-78152-0-15593400-1398859697_thumb.jpost-78152-0-21935700-1398859715_thumb.jpost-78152-0-21834700-1398859733_thumb.jpost-78152-0-62851000-1398859756_thumb.jpost-78152-0-13973400-1398859777_thumb.jpost-78152-0-49364700-1398859792_thumb.jpost-78152-0-69357600-1398859804_thumb.jpost-78152-0-63980600-1398859824_thumb.jpost-78152-0-05548700-1398859851_thumb.jpost-78152-0-10604900-1398859887_thumb.jpost-78152-0-06814800-1398859911_thumb.jpost-78152-0-92563500-1398859928_thumb.jpost-78152-0-85313000-1398859941_thumb.jpost-78152-0-42883800-1398859957_thumb.jpost-78152-0-87579400-1398859973_thumb.jpost-78152-0-93531300-1398859992_thumb.jpost-78152-0-28527100-1398860011_thumb.jpost-78152-0-52031200-1398860026_thumb.jpost-78152-0-64064200-1398860038_thumb.jpost-78152-0-50124500-1398860087_thumb.jpost-78152-0-78597300-1398860099_thumb.jpost-78152-0-11342300-1398860115_thumb.jpost-78152-0-64993800-1398860130_thumb.jpost-78152-0-91597600-1398860147_thumb.jpost-78152-0-35936000-1398860164_thumb.jpost-78152-0-12674700-1398860178_thumb.jpost-78152-0-34171800-1398860195_thumb.jpost-78152-0-89839000-1398860213_thumb.jpost-78152-0-09969700-1398860263_thumb.jpost-78152-0-71311500-1398860306_thumb.jpost-78152-0-17047000-1398860356_thumb.jpost-78152-0-80589100-1398860380_thumb.jpost-78152-0-68872800-1398860403_thumb.jpost-78152-0-29541900-1398860425_thumb.jpost-78152-0-58489100-1398860436_thumb.jpost-78152-0-63501700-1398860458_thumb.jpost-78152-0-49178700-1398860477_thumb.jpost-78152-0-86780800-1398860501_thumb.jpost-78152-0-24923800-1398860530_thumb.jpost-78152-0-03668100-1398861540_thumb.jpost-78152-0-50810900-1398861551_thumb.jpost-78152-0-89376800-1398861568_thumb.jpost-78152-0-58148100-1398861583_thumb.jpost-78152-0-34976100-1398861606_thumb.jpost-78152-0-09659900-1398861625_thumb.jpost-78152-0-78384200-1398861644_thumb.jpost-78152-0-89681000-1398861664_thumb.jpost-78152-0-61782100-1398861680_thumb.jpost-78152-0-02235600-1398861705_thumb.jpost-78152-0-36995300-1398861752_thumb.jpost-78152-0-13882100-1398861789_thumb.jpost-78152-0-15039700-1398861812_thumb.jpost-78152-0-13365400-1398861825_thumb.jpost-78152-0-22536500-1398861847_thumb.jpost-78152-0-35782800-1398861870_thumb.jpost-78152-0-92540200-1398861885_thumb.jpost-78152-0-23580900-1398861904_thumb.jpost-78152-0-13741800-1398861925_thumb.jpost-78152-0-83359300-1398861941_thumb.jpost-78152-0-60765100-1398861987_thumb.jpost-78152-0-78083800-1398862025_thumb.jpost-78152-0-01829100-1398862053_thumb.jpost-78152-0-42670900-1398862078_thumb.j
Hope you like it,
Please comment!!
post-78152-0-96351200-1398379336_thumb.j
CPU - Intel Core i7-4790k OC @ 4,4GHz Motherboard - Asus ROG VI Gene Z87  GPU - Asus Gtx 690 4GB
Ram - 32GB HyperX Beast 2133 mhz  Case Parvum|Beast Watercooled & Modified  Storage - Samsung EVO 840 120GB SSD + 2 x Samsung EVO 840 250GB SSD's
Looks very interesting, looking forward to seeing the finished build. Black and gold is hella slick.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
That's nice! Welcome to the forum!
yep i know, was thinking bout getting 780ti instead and leave out the ssd 1tb,
but allready had a 680, so only had to get 1 more :) and allready had the ssd also :)
But thx so far guys, still waiting for the fan controller to arrive,
then i'll start building it :)
Updated new images, started building :P looks awesome so far ! :D
The build is now complete <3<3
i will upload images very soon of the final build process and images of the Finished BUILD<3<3
if you have any questions about my thought process during the build, please ask away and ill do the best i can to answer
I had 1 leak from reservoir to the pump, tried 3 times to fix it, but ended up using the old res top with single hole, as the buttom instead, wich fixed the leak ..
i made 2 acryllic plates, covered 1 side of it with carbon foil and put one in the buttom of the case, as a mirror wic reflects all the gold <3<3,
and the other plate i put in the back to cover up the SSD's
Looks great,,
Idle temps
CPU 27 Degrees
GPU 25 Degrees
Load temps
CPU 45 Degrees
GPU 40 Degrees
<3
This is pure epicness dude. Great colour!Can't wait for the finished pictures.
Looks awesome! Try to take some outside pics or if you have a DSLR camera take some pics without the flash and mounted on a tripod.
My build:  Leviathan  Case: 900D  CPU: i7 3770K (watercooled)  Mobo: Z77X-UD5H GPU: EVGA GTX 780 Hydro Copper GPU: MSI GTX 780 watercooled PSU: EVGA 1300W G2  RAM: 32 GB Corsair Vengance  HDDs: 1 x 120 GB Intel 330 SSD (OS X); 1 x 256 GB Samsung 840 pro (Windows 8); 2 x 2TB Seagate Barracuda (RAID 0 Data OS X); 1 x 3TB Seagate Barracuda (OS X backups)  Monitors: 1 x 24" Apple LED Cinema (center); 2 x 23" Apple LED Cinema (surround)  Watercooling: 3 rads, CPU, GPU, GPU, MCP655 pump, Lots of fittings, EK reservoir, EK UV Blue coolant.  Updated build: Leviathan 2.0
i will try just dont have a decent camera, but will do once i borrow one from a friend :)
It's amazing what a little spray paint can do. Well done
it sure is !! .. never underestimate spraypaint :D !!
thx sooo much :)
The Monsoon fittings are soooo sick  :o
They are indeed !!
only thing i dont like about them is that 90 degree and 45 degree fittings dont allways have the same gold colour..
so some of the 90 degree fittings have a darker gold colour than the rest..
but oh well, too late to fix that now :D
wow, nice to see some more black and gold.
  i5 4440, 8GB 1600 mhz, Gigabyte Z87X-UD3H, SX900 128gb SSD, 850w 80+ Gold, FD R4, 270
Very nice! Excellent color.
thx, was thinking black/silver/purple at first, but i think thats gonna be my next build :)
glad u like it :)
just messed a little with the OC,
currently at 4,4GHz with 1,25v with max temp of 76 degrees on 100% load..
idle temp at around 32 degrees..
Is that good/safe temps ??
i was scared that you were gonna overdo the gold, but you didnt, very nice!
id go untill your CPU reaches 80°C
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
thx very much bro !!  yea i think its a nice blend, wag gonna do custom backplates for gpu's and custom sli bridge cover with all the logos from corsair, intel and so on, but i think it would have been too much..
allright, so 80 under 100% load is a goal then..
what should normal idle temps be at, and temps while gaming ?
off cause depending on ambient room temperature ?
if your ambient temp is about 20-22 everything under 35°C is very good, ive never really seen idle temps under 30°C, even with the most amazing WC loop (altho those usually have GPU's with alot more heat output)
allright, awesome, thx alot for that :) ..
OMG THE GOD DAM SEXXYNESS IS AMAZING
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
haha <3<3 Thx man !! .. really love all the good response, would never have dreamed that my first ever watercooled/modded pc would turn out this great ! :D
so makes me very happy that you all like it :D
