I'm new to PC as im coming off if PS4 and u have no idea as to what parts to use
Budget (including currency): £1300
Country: England
Games, programs or workloads that it will be used for: GTA 5, Warzone, Minecraft and csgo
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): already have a mouse and headset. I would like to play at 144hz refresh rate and 1080 or 1440 resolution. I'm going to buy a razer keyboard.
I made this list
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£269.38 @ Amazon UK)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (£115.40 @ Alza)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  (£98.77 @ Newegg UK)
Storage: Western Digital Blue SN550 250 GB M.2-2280 NVME Solid State Drive  (£48.30 @ Amazon UK)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£52.95 @ CCL Computers)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  (£474.98 @ AWD-IT)
Case: NZXT H510 ATX Mid Tower Case  (£72.45 @ Amazon UK)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  (£79.99 @ Currys PC World)
Monitor: ViewSonic VX2758-2KP-MHD 27.0" 2560x1440 144 Hz Monitor  (£318.57 @ Currys PC World Business)
Total: £1530.79
Generated by PCPartPicker 2020-08-06 22:23 BST+0100
6 minutes ago, Darpyface said:
I made this list
Total: £1530.79
That's a bit over my budget
1 minute ago, BlueScope819 said:
Do you think you can wait for two months until next gen parts come out? It's the same architecture as what's being used in the next gen consoles so you will have much better price to performance.
I need a computer not only for games but for school stuff aswell, my laptop has served me well over the years
What razer keyboards? The majority of them are shit with bad switches, build quality and keycaps.
2 minutes ago, BlueScope819 said:
Okay. So you think your laptop can tide you over two months until next gen stuff comes out? You will get much better performance for the same price.
It literally won't turn on anymore, I've tried changing it and all but still won't turn on
You can cheap out on a couple of things,
You don't need a hard drive right away you can save up and get it later
You can get a worse case since it doesn't really affect performance
You can get a 1080p or a 60Hz monitor
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Cynosa chroma probably, don't need something expensive af rn.
Why are you spending £80 on a membrane keyboard? Get something like a GK61 from aliexpress.
3 minutes ago, BlueScope819 said:
Fair enough, seems like you need it. People like @Mateyyy have provided some great options, you should check them out.
Will they run the games im gonna run?
I'll look into the keyboard then, thanks for the suggestion
They will definitely run those games well. You should look at the build @Mateyyy posted but instead of a 2070 super get a 5700xt. Even the ones with good coolers like the 5700xt gaming oc are over 100 less. They have slightly lower performance, no raytracing, and dont have nvec encoding but they have a much better price to performance (and should still run the games you want at 144fps). If you do get the 2070 super get it sooner than later as they just stopped manufacturing them so they will soon go out of stock and raise in price even more. It will be about 150 under budget so you can either save that money, get a 3700x, or the best thing would be to add more storage. Either another 1tb ssd or 2-4tb hdd.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Considering this is OP's first time building and using a PC as their daily, I wouldn't recommend a 5700XT, simply because of the potential of driver issues popping up.
Havent all the driver issues been fixed by now? I thought that was only an issue at the beginning.
PSU Tier List
SSD Tier List
PARROT GANG
So i should just swap out the storage.
It's surely a lot better than at launch, but not all of them have been fixed.
No, leave the one thats there as it is a great ssd. If you have money leftover in your budget, you can add a hdd to your system.
PSU Tier List
SSD Tier List
PARROT GANG
Okay, thank you very much
