HELP ME WITH MY BUILD
BahaYasin
IVE RECENTLY MADE A NEW LOW BUDGET BUILD FOR GAMING.  EVERYTHING WENT FINE AND I CAN PLAY WITH 60 TO 70 FPS WITH MEDIUM GRAPHICS BUT IM HAVING A FREQUENT AND RANDOM FRAME DROPS DOWN TO 10 OR 5 FPS  WITH SUDDEN SCREEN FREEZ FOR 1 OR TOW SECS.
THESE FRAME DROPS SOMETIMES HAPPEN EVERY 30 SECS AND SOMETIMES HAPPENS EVERY 1 OR 2 MINUTES  AND ALSO  IF I GO INTO A CONFLICT OT HEAVY GRAPHICS SENCE IT HAPPENS
And I've tried setting graphics to lowest settings but it doesn't matter fram drops are the same
  PC SPECIFICATIONS:
MBD: MSI B450 PRO-VDH PLUS
CPU: RYZEN 3 2200G
RAM: CORSAIR VENGEANCE 3000MHZ 2*4BG
PSU: CORSAIR VS450 80+
HDD: SEAGATE BARRACUDA 2TB 7200RPM
GPU: ASUS GEFORCE GTX1050TI OC 4GB
  WHAT IVE DONE TRYING TO SOLVE THIS ISSUE :
UPDATING GRAPHICS CARD DRIVER
UPDATING CHIPSET DRIVER
UPDATING BIOS
FORMATTING AND REINSTALLING WINDOWS
CHANGING GRAPHICS CARD
CHANGING OPERATING SYSTEM
PLUS ALL WINDOWS UPDATES AND ALL OF THE DRIVERS ARE UP TO DATE
SO WHAT IS THE ISSUE DO I HAVE A BOTTLENECK IN MY BUILD
IS IT MY HARD DRIVE THAT MAKES THESE FRAME DROPS? SHOULD REPLACE IT WITH SSD?
I'd get a SSD regardless if it's the problem or not, great upgrade
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
Sounds like you're likely being bottlenecked by your CPU. The 2200g is "ok" but its fairly underwhelming in terms of raw gaming power being just 4 cores and no SMT. Check your CPU usage, sounds like you're hitting 100% usage.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
NO, MY CPU USAGE IS 70-80% AT MOST
BY THE WAY, IT HAPPENS WITH SMALE GAMES THAT USES ONLY 30% OF THE CPU
IN MY OLD BUILD HDD DID NOT MAKE THIS PROBLEM
AND AS I KNOW BARRACUDA IS GOOD FOR GAMING
Still though, a SSD is a really good upgrade and I'd recommend using one as your boot & programs drive.
I WILL BUY ONE FOR SURE. BUT IM AFRAID THAT IT WILL NOT SOLVE THE PROBLEM
It probably won't, but it's still a good upgrade nonetheless. No idea what the problem could be though
I WILL. BUT  FIRST I SHOULD SOLVE THIS PROBLEM
I do agree with you.
tried older or latest version of the graphics driver?
Can Anybody Link A Virtual Machine while I go download some RAM?
Bro, what’s with the caps lock man?!
An ssd would be a great upgrade, your hdd shouldn’t be causing this problem though.
Maybe try overclocking your cpu, MSI Afterburner makes it easy.
And try that too.
I got a ps5 and a pc pretty ballin
NO, I didn't! I've only used the last version of the graphics driver
may that make a difference?
And try that too.
Yeah I'll buy an SSD for sure but as you said it's not going to solve the problem
I've tried overclocking my GPU by MSI afterburner and also overclocked the CPU up to 3.9 GHz
but still the same
What's up with the caps? Chill out, hopefully you'll find a solution.
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
Sometimes I do like writing with caps :D
I hope to fix this problem, I'm not gonna leave it just like this, it's not playable at all
I've done everything right but problems just happen :(
Alright man, just ease up on the caps. There are people on this forum who will just refuse to help you outright if you're spamming caps.
I didn't know that! sorry for all it's just my bad English.
It's alright man
