Quirk - RTX2070 "hot" audio output
Automobili3XF
Recently i went from a GTX1070ti to an RTX2070 and i noticed a quirk.
I've been using it on my AV setup (which has a Denon AVR-X2400H receiver), the volume sweet spot with other devices and the GTX is around -27db, but after i got the RTX the volume sweet spot for me with it is around -37db, which indicates it sends the audio signal +10db higher to my receiver.
Thankfully it doesn't affect quality or compatibilty and the fix is as easy as lowering the volume on Windows.
Has anybody else noticed this?
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
Your windows audio settings may have changed, go to the sound control panel and take a look at the volume output for the digital audio.
4 minutes ago, TrigrH said:
Why?
Seconded, was there any difference?
Personal Desktop":
Luna, the temporary Desktop:
1 hour ago, TrigrH said:
Why?
RMA, the GTX1070ti developed a heinous case of coil whine and Zotac gave me an RTX2070 under warranty,
At max, like it was with the other card, i control the volume from the AVR.
I also have it configured to output at 24bits/192000hz with 5.1 surround support.
