Posted November 15, 2018 I took my acer nitro 5 laptop to reapir shot due to fan's buzzing noise. They told me that bearing is worn off. But thing is, buzzing noise only occurs when its on lower rpm. When I game, I do not hear buzzing noise. Is it dust blocking a fan or any idea? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 What OS are you using? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 Author 1 minute ago, David Anderson said: What OS are you using? windows 10 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 Just now, DC said: windows 10 Check your CPU if it's high. If it's not, then it supposed to be a fan problem. Might have to replace it. If it's high ( I totally didn't mean drugs here ), you have to eliminate the process that it's stealing all of your CPU Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 Author 2 minutes ago, David Anderson said: Check your CPU if it's high. If it's not, then it supposed to be a fan problem. Might have to replace it. If it's high ( I totally didn't mean drugs here ), you have to eliminate the process that it's stealing all of your CPU temps looks fine to me, just like for school use, browsing internet or using docs, temp is around 40 to 45C When I game, it is around 70 C so I don't think fan is bad Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 3 minutes ago, DC said: temps looks fine to me, just like for school use, browsing internet or using docs, temp is around 40 to 45C When I game, it is around 70 C so I don't think fan is bad Is it better now? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 Author 1 minute ago, David Anderson said: Is it better now? that is the temp im getting with buzzing fan, it buzz around like 2k to 2.5k rpm and it if goes up, it does not buzz Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 15, 2018 2 hours ago, DC said: that is the temp im getting with buzzing fan, it buzz around like 2k to 2.5k rpm and it if goes up, it does not buzz I am thinking that you should leave it there. It cannot be replaced I think because if you want to replace, you have to find the correct size, shape, and manufacturer Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
