Desperate for help..
Go to solution Solved by imreloadin,
2 minutes ago, DinhanhGamer said:
What is that? Is it this one?
Did you even look at your manual? That's literally the very first thing listed in the board layout...of course you need to plug those power cables in to supply power to the CPU.
I just fully assembled by pc, but I don’t have the gpu yet because the one I want is out of stock.
after I plugged everything and fired it up. The motherboard lighted up and so did the aio. (I used an asus rog maximus xi code). But then I wait for a while and saw no images on my monitor, I checked the Q-code of the motherboard and it said 00. How do I fix this what should I try to do? (When I unboxed the motherboard, 3 screws at the back was broken and fell off, those screws are for contact with the case I think..)
Any opinions really helps, thank you
https://linustechtips.com/topic/995035-desperate-for-help/
What is your processor?
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967043
Gonna need the specs of your system to be able to do much more than guess...
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967045
Yes. That's where/how the CPU draws power. Without that no computer would function.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967061
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967070
Wait I thought that it’s in the whole 24 pin thing?
That's for the rest of the motherboard. You need to plug in power for the CPU.
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967074
I might be dumb
Don't beat yourself up! You can just add this story to the 'dumbest thing I've done while making a computer' thread  ;)
We've all been there.
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967077
I shocked myself this way too when building. Mistook CPU for GPU power (despite the plug having CPU) written on it. I wondered why I had killed my lovely new rig until I realised I too was one power cable short!
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967347
3 hours ago, DinhanhGamer said:
Yup, I’m dumb, the bios has booted up now, do I now need to install windows 10 using a usb? Or is there anyway else cause I heard about being to install windows 10 without anything
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967562
A what? Without anything? Those must mean that you connect drive with existing Win10 install. The OS can't just magically pop in your drive. Someone needs to install it. And if this is new build with all or most components from the box, then it means that you are the one installing OS. With USB, unless you have optical drive and DVD.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/995035-desperate-for-help/#findComment-11967758
