Do I need router when I care only on Cable?
Arwinnd
Hi as the topic is, will my connection go more stable, or without some distortion or would it be more reliable due to more RAM and better processor in router when I use cable connection? Or is it that in that case it would be barely noticable and it doesn't matter that i have modem router combo when i care about cable? Does somebody know the truth about this topic?
If you have a modern router then there should be no worries about connecting an Ethernet cable
Primary PC:
The only downsides to using a cable company supplied combo unit are,
The settings may not be as configurable as some might like...guest network, bandwidth priority for streaming, whatever.
The single wireless access point may, or may not, give you adequate coverage of your living space, causing wireless dead/slow spots.
If you don't have problems, or need those features, you should be fine.
I am glad you guys knew what he was talking about... because from his post I have no fn clue what he is asking lol/
Just if external router would help in packet loss or something when i use cable connection to the unit.
