Power supply
Go to solution Solved by Adhiraj patil,
7 minutes ago, vjizzle2384 said:
That old style does that even have GPU connection cables cause my old PSU that I use for downloading movie only PC don't.  Just spend $50 on a 80+ Gold PSU they are cheap at this moment.  Come on Mr Patel.
Can you refer me one and can I replace my existing psu with that? I mean can I keep only one psu in my cpu?
6 minutes ago, Adhiraj patil said:
I ball Stella cabinet with iball zps- 281 psu.
a wat
https://linustechtips.com/topic/992599-power-supply/#findComment-11944597
16 minutes ago, Adhiraj patil said:
Isn't 450 w enough for gtx 1050ti?
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/992599-power-supply/#findComment-11945815
https://linustechtips.com/topic/992599-power-supply/#findComment-11945832
22 minutes ago, seon123 said:
Depending on what's available and the pricing, be quiet System Power 9, be quiet Pure Power 10 400W, Corsair CX450, Corsair Vengeance 400W, or Cooler Master Masterwatt 450W.
Crosair CX450 will be enough right and I can replace it with my current psu right ?
https://linustechtips.com/topic/992599-power-supply/#findComment-11945837
9 hours ago, Adhiraj patil said:
Hello guys, recently I built a desktop and I just wanted to know that can I use Asus gtx 1050ti phoenix edition on this pc.
My specs are
Msi h110m pro vh1 plus motherboard
Intel i5 7400 processor
8gb ddr4 ram
Holy shit, that's something that can (or rather will) kill the Hardware and possibly you.
Something like this:
https://www.theregister.co.uk/2012/11/26/exploding_computer_vs_reg_reader/
And the Important part:
Quote
who lives in Germany,
Be Quiet Pure Power 10, 400W and more
if it has to be cheap:
System Power 9 400W and up
Xilence Performance A+
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/992599-power-supply/#findComment-11946096
What do you say about crosair CX450?
https://linustechtips.com/topic/992599-power-supply/#findComment-11946286
There’s nothing wrong with that it is a good power supply
My PC:
My Kids PC:
https://linustechtips.com/topic/992599-power-supply/#findComment-11948535
15 minutes ago, Adhiraj patil said:
Sorry but I don't know much about these things. So what is modular and non modular?
My PC:
My Kids PC:
https://linustechtips.com/topic/992599-power-supply/#findComment-11949359
11 minutes ago, vjizzle2384 said:
Technically that's a Semi-Modular power supply...
Modular power supplies have cables that can be detached from the unit. This is helpful if you want to remove some of the cables you aren't using. Also can make cable management a bit easier. Modular PSUs are typically slightly more expensive than non-modular versions. There are tree types
Fully Modular - All cables can be detached from the PSU
Semi Modular - The Motherboard & CPU cables are fixed, but the SATA, PCIe, and Molex cables can be detached (may vary depending on model)
Non modular - All cables are fixed to the PSU
https://linustechtips.com/topic/992599-power-supply/#findComment-11949384
wow i didn't know system power 9 400W was DC-DC
https://linustechtips.com/topic/992599-power-supply/#findComment-11949492
So did u get one
My PC:
My Kids PC:
https://linustechtips.com/topic/992599-power-supply/#findComment-11969576
