SQL Help
Go to solution Solved by dwang040,
As someone who is also just learning sql and php for a course, I can agree that W3schools has helped me out a lot. The basics of sql in general should not give you too much trouble. I think the hardest thing (for me) is dealing with multiple sub queries and joins. But in the end, while it can get messy with those larger queries and sub queries, as long as you understand what you are trying to get and have a good idea of how to get it, I believe you'll do fine.
So, I need to learn SQL for an assignment. I am doing SQL while the rest of our class is doing HTML. Because I am fluent in HTML the teacher moved me up. Here is the problem. I need to learn it all myself as the teacher is teaching SQL. Can I have some basic stuff. What to do. How to start.
idk tbh
https://linustechtips.com/topic/992294-sql-help/
w3schools is honestly pretty good for SQL.
https://www.w3schools.com/sql/
I would say to use that as a guide and then download some database -- wikipedia/IMDB -- and play around a bit on a local database.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/992294-sql-help/#findComment-11941688
8 minutes ago, LeapFrogMasterRace said:
SQL ? id rather just play it dumb with HTML
SQL is nice. HTML is terrible.
PSU Tier List | CoC
https://linustechtips.com/topic/992294-sql-help/#findComment-11941734
Sql is nice if you have rigid data.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/992294-sql-help/#findComment-11942550
https://linustechtips.com/topic/992294-sql-help/#findComment-11944033
  • 4 weeks later...
The syntax diagrams over at https://sqlite.org/lang.html are helpful in understanding how to construct many different SQL commands. Also, IMO SQLite is a good dialect of SQL to get started with because it doesn't have a lot of the extra bells and whistles that the big databases have and is easy to setup.
https://linustechtips.com/topic/992294-sql-help/#findComment-12025989
