Assuming you'll use rebates.
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($97.99 @ SuperBiiz)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($70.98 @ Newegg)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($46.99 @ Amazon)
Storage: Western Digital - RE4 1TB 3.5" 7200RPM Internal Hard Drive  ($40.88 @ Amazon)
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.44 @ Amazon)
Monitor: LG - 24MP59G-P 23.8" 1920x1080 75Hz Monitor  ($132.99 @ Amazon)
Keyboard: Redragon - K552 Wired Gaming Keyboard  ($29.99 @ Amazon)
Total: $569.24
Generated by PCPartPicker 2018-11-07 02:13 EST-0500
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11938802
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11939825
20 hours ago, Westy55 said:
Hi! I need a pc, keyboard and monitor for 600 dollars.
My main focus here is upgradability I really don't have any brand preferences.
U.S. Btw
Build something like this instead....
Got in a discrete GPU...
Also, you can utilize the free sync provided in that monitor...
CPU: AMD - Ryzen 3 1200 3.1 GHz Quad-Core Processor  ($94.00 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($70.98 @ Newegg Business)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card  ($139.99 @ Newegg)
Case: Raidmax - Ninja II ATX Mid Tower Case  ($25.98 @ Newegg Business)
Monitor: Acer - KG221Q 21.5" 1920x1080 75Hz Monitor  ($109.99 @ B&H)
Keyboard: Thermaltake - Commander Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Total: $621.25
Generated by PCPartPicker 2018-11-07 20:23 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11941879
1 hour ago, LOOK OVER HERE said:
A 2600 six-core with a 1050 Ti also fits if you're careful.
I understand the processor is a good choice, but having to buy a GPU and then sell it later to buy a better one seems like a lot of extra steps. The 2400g performs close to the 1050ti anyway.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11941953
Is it??
But the benchmarks show a different story. They say that it performs similar to gt1030. With gt1030 beating the 2400g in most of the cases. Yet alone, 1050ti is around 40% faster than 1030.
IDK where u got those numbers from.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11941974
Sources?
Though you are right about the graphical performance, do you have a pcpartpicker link that fits into his budget with that build?
We don't really even know what OP wants to use it for. I assume gaming. Personally, I would rather have integrated graphics until enough money is saved for a GPU that is better than a 1050ti. I personally don't like to deal with the extra step of selling the GPU.
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11942025
1 hour ago, MandoPanda said:
Sources?
What do you think about this build?
An SSD is a small investment ND can be added later on, so skipped it.
Also, I hv added in a GPU that's faster than a 1050ti and a monitor that supports Freesync.
Total: $621.25
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11942271
You have done well. I like SSDs to be added right away because people who are not tech savvy might not be able to easily clone their HDD to an SSD and then reformat the HDD. This is the case that they don't want to reinstall and lose all of their files.
I think your build is a good balance for the budget.
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11942313
Or else he can do it the other way. Add in a SSD now and save up later for a HDD.
Storage: Samsung - 860 Evo 250GB 2.5" Solid State Drive  ($55.99 @ Newegg)
Total: $631.35
Generated by PCPartPicker 2018-11-07 23:01 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/991942-first-pc-build/#findComment-11942339
