I was messing around with an old laptop I had been given , the screen is broken so I took the whole thing apart so it was just the basics. Hooked up to a hdmi I installed a New operating system onto it . I had it working fine all evening until I decided to try my luck and plug in a different laptop screen I had lying around (realising that it 99% wasn’t going to fit but worth a try) . Rushing around I was trying to plug it into the motherboard and realised it wasn’t going to fit but I was actually trying to plug it into the wrong side of the connector which caused a few tiny sparks , after that I realised that the battery was still connected and was still plugged in on charge ! Sad
Pretty much as soon as the small sparks happened the orange charging light went off.
The laptop will not power on or show any means of life , no lights no fan , no noise what so ever . The charging power supply still works As tried the light is still on the brick.
So annoying . A good little project was going so well until this happened.
Have I totally fried the motherboard?
Any help would be much appreciated.
Cheers
https://linustechtips.com/topic/991861-laptop-no-power/
Rip laptop. At least it was an old laptop that you were just tinkering with, not your daily driver or something.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/991861-laptop-no-power/#findComment-11937768
