Coax to Ethernet?
1 minute ago, iKingRPG said:Ok sorry if I wasn't specific I write that quickly. So my house is wired where rooms have coax ports in the wall and those wires run all the way down to the basement into a closet where the router and switch is. So could I have so I put the Ethernet in the switch and convert it to coax to go through the wires that run to the wall ports? And I would then put adapters on those wall ports so I can connect computers? Also do you think that would limit speeds to where I should just use Wi-Fi? Thanks.
Well, if the wires are isolated (all runs go down the basement), you can use a bunch of moca adapters (one per line) to get ethernet to each room. Expensive though.
No, Moca is quite fast. I believe it's 600 Mb/s rated. My old verizon moca install handled 150Mb/s with ease (before I ran ethernet to the ONT outside)
