Help soldering USB keyboard
Solved by mariushm,
See http://pinouts.ru/Slots/USB_pinout.shtml
Link above says which color is each data wire.
edit:eh, if you're lazy...
| Pin | Name | Cable color | Description |
| 1 | VCC | Red | +5 VDC |
| 2 | D- | White | Data - |
| 3 | D+ | Green | Data + |
| 4 | GND | Black | Ground |
V voltage
G ground
S shield (the sleeving material around the 4 wires in the cable, if there is any.)
