Tried to build a pc out of some old parts today.
I wanted to test to see if the parts worked and plugged in the 24pin and 4pin atx connectors into the motherboard together with the cpu fan. When I shorted the power button connector the fans started to spin and stopped a second later. I took out the cpu and tried to start it and the fan started spinning. I put back the cpu and tried to start the system but the fan started spinning and stopped a second later with no display.
specs:
intel core 2 quad q8200
asus Benicia motherboard
4gb ddr2
antec truepower 650
Main Desktop:
Intel Core i7-13700KF (5.5GHz, -0.1v Offset), Lian Li Galahad 360 AIO, Asus ROG Strix Z790-A Gaming WiFi, Gigabyte RTX 4070 Ti Super Aero OC, 2x16GB G.Skill Trident Z5 RGB DDR5-6000 CL36, 4TB Samsung 990 Pro, Corsair RM850x Shift, Phanteks NV5 w/ Lighting Kit
Peripherals:
Alienware AW3423DWF QD-OLED, Logitech G502 X Plus, SteelSeries Aerox 3 WL 2022 Snow, HiFiMan Sundara, Sennheiser HD 560s, Cooler Master MH630, Schiit Modi 3e, Schiit Magni Heresy
Laptops:
Asus ROG Zephyrus G14 (Ryzen 9 8945HS, RTX 4060)
Phones:
Samsung Galaxy S24 Ultra 256GB, iPhone 14 Plus 128GB
https://linustechtips.com/topic/989631-pc-won%E2%80%99t-start-up/
Do you have a gpu?
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
3 minutes ago, Lemtea said:
Do you have a gpu?
the board should have integrated graphics. Right now I can’t even get the system to start so thats the problem
Main Desktop:
Peripherals:
Laptops:
Phones:
Since the board stops working when you put in this CPU, try a different CPU to make sure it's not just a dead board.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I don’t actually have another cpu though. Nobody who I know uses an lga775 cpu anymore so I don’t have a way of testing that out
Main Desktop:
Peripherals:
Laptops:
Phones:
Then you'll have to buy one. A core 2 duo or pentium can't be much more than a few bucks.
