1 hour ago, Vibora said:
Hey, Im in need for a 600w power supply. Main uses will be gaming.
Thanks.
If you need a 600W Power Supply, you can afford a high end one like a Corsair HX750i or be quiet Dark Power Pro P11 750 (or better 850W in this case)
If you only use a normal system, with mid range components for up to 1000€ or so for the whole system, you'd need a good quality 400W, with 500W to be preferred.
And here we have things like Bitfenix Formula, Whisper M, be quiet Straight Power 11.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902382
Why are be quiet PSUs overpriced? At least in my opinion
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902404
Because they "waste" money on the fan.
A good quality fan can make a difference of up to 20€.
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902418
Just now, 17030644 said:
Do you think silent wings are the best fans on the market (when it comes to PSUs)
They are! Super silent and the whole BeQuiets are simply well build with good quality components
german engendering :)
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902424
good quality components isn't something only be quiet makes
nor is the noise levels
that's why I asked, for example @Stephan Payne mention the bitfenix whisper M, that's high-quality and silent and usually costs less. There's also the RMx/RMi etc
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902432
Yesm as there is no serious competition in this case.
The fans probably survive the PSU, though only 2pin (and don't use the standard Fan Connector) and in a proprietary format...
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902457
1
but hold on a second pure power 10 doesn't use any silent wings and still costs more maybe in germany it's not the case
It'd be nice if be quiet released a titanium PSU
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902462
They will soon I think
yes pure power uses cheaper fans but they are also nice.
In germany the Price differences are a but less but still I think it can be worth it for the general quality of components
but you could also go with a Corsair unit
they make nice ones to (and cheaper ones)
lile i said RM650(i) allso super silent
i am running aHX (Same fan) and cant hear anything while the rest of my PC is full Noctua custom loop
sooooo it’s FINE
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902471
4
We'll see. Even nowadays you don't see very low-wattage titanium units and that is to be expected, really.
The cost of a lower-wattage titanium isn't very different from a high-wattage one and the people that benefit the most is the people that need lots of watts and run their systems 24/7.
Still, I believe It'd be nice to have more competition in that segment.
1
they also make garbage, but I know they have very good units indeed
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902479
Yeha... everything from RM and Up! is fine
for general use a gray(!) label CX unit or the „vengeance“ series is fine
yeha they call everything vengeance...
https://linustechtips.com/topic/988078-600w-power-supply/#findComment-11902490
