HELP! new SSD not performing as it should (i think)
Solved by Electronics Wizardy,
2 minutes ago, i_build_nanosuits said:especially on the write speed it seems a lot more consistent now...and i didn't do anything different, only used another benchmark tool...wierd
What do you think? normal? i shouldn't worry about it anymore and go play games then?
Stop worrying and enjoy the systems, your drives are fine.
