PC Power Options: Balanced or High Performance?
Solved by Xcoool,
4 minutes ago, A Random Dude said:So there IS a reason to switch between profiles, I KNEW IT. I won't be installing an app to do so. That's just another thing to worry about running in the background. While the process is painfully time consuming, it doesn't bother me so much when the performance I get from it is totally worth it. Same with all the other things I do right before I run a game. But thanks for the heads up on the app. It gives me peace of mind in knowing that there IS a reason to switch between power plans. Especially when it comes to gaming and this topic of discussion.
It comes down to your rig,with new highend systems there is no much point.With less powerful hardware or older stuff,switching profiles can improve your experience.
