I5 8600K issue with Corsair H55i
Suchy2904
So straight to the issue recently I updated my PC with new parts like
-Graphics card - GTX 1060 6Gb44579045_1815802488530274_1392466858795335680_n.thumb.jpg.6426f20ed98a447a8a10e18d94213d59.jpg
-Motherboard -ASUS TUF Z370-PLUS Gaming
-CPU - Intel I5 8600k
-RAM- Corsair 2x8 Gb 2400MHz
-Case - Corsair Obsidian 750D
I have a problem with my temps, when at first I put everything together it was fine but after some time temps on cpu started to rise up slightly under load for like few degrees but after a week or two temps started to go even higher up 10 or even 20 degrees so I thought maybe I just put too much thermal paste or something so I changed it .Everything get back to normal so I was happy, after another 2 or 3 weeks it happened again even more rapidly ,now I’m after tree thermal pastes and like 10 changes of paste and I decided to ask for help of professionals in this kind of stuff because in my opinion it’s my cooler but I’m scared it could be my cpu . And if it’s actually a cooler then I would like to ask for advice about which one should I buy for replacement. Thank you ?
I think it’s the paste that you are using is bad. Did you try different paste?
yeah give that a go, maybe also the cooler some how be loosening itself over time are the nut tight when you go to change paste?
i7-8700k @ 5GHz || MSI Z370 Sli Plus || Gigabyte G1 Gaming GeForce GTX 1080 || 250GB 970 EVO NVMe SSD, 250GB WD Blue SSD, 1TB WD Black HDD, 4TB WD Blue HDD
Corsair Vengeance RGB CL141818 3200Mhz 2x8GB || Corsair Obsidian 500d RGB SE || Corsair H150i || Corsair RM750x || Acer Predator XB241H, Acer G257HL
What exactly are your Temps?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I used tree different pastes and yes i tight it up even i tried spacing the back plate .
So that’s the temps rn when I play games it goes to even 95 degrees When just after changing the paste It’s like 31-34 in idle and 55-65 underload sometimes 70
