Hello and thanks for looking and helping. Would like to stay about 1k or under with this build. I will be using this for everything from games to simple office work. This is just a starting point and would like to fine tune everything before I start buying..
http://pcpartpicker.com/user/anthony81/saved/3luq
https://linustechtips.com/topic/98267-options-and-advice-for-build/
Do you burn a lot of media?
If not I'd probably skip the disc drive.
Is the wireless adapter needed?
I only ask because I've had friends that just assume they need one.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I wouldn't spend that much on a non-mechanical keyboard. Either buy a cheap one or spend the extra ~$30 for a mechanical. I would only get the blue ray drive and card reader if you absolutely need them. You should also probably get a better motherboard. And get a cheaper wireless card unless you have a 5ghz router that you want to use.
It's not bad, but if you could expand your budget, remove the OS, card reader, and BD drive you could get a much better z87 mATX board and i5k.
The wireless adapter is needed and need dual band. That was the cheapest i found so far. I do burn allot of media and while i was buying new i thought might as well get a Blu-ray burner/player. The card reader i do need.
Thanks, Do you have a mechanical in mind? Would perfer backlit keys. I will be using a dual band router. As for the motherboard what would you have in mind for that? Thanks! I'm trying to get a solid list of parts then i will go hunting for sales.
I have a CM Quickfire TK with Cherry blues (http://www.amazon.com/CM-Storm-QuickFire-TK-Mechanical/dp/B00A378L4C/ref=sr_1_2?ie=UTF8&qid=1388962448&sr=8-2&keywords=quickfire+tk), I really like it and it is fully backlit and is about as inexpensive as you can get for a backlit. If you wait the price will probably go down, I got mine for like $65 after a rebate. I don't know much about which motherboards are good and which aren't, I know its not good to cheap out on them though. You may want to ask someone else or start a new thread for that.
Thanks for the reply's. I did some updates still looking for a cheaper keyboard/mouse(back-lit) make room for a nice headphones with microphone.
I found an old card reader i had, its cheap but it will do..
Original build
New
http://pcpartpicker.com/user/anthony81/saved/3m6p
Looks pretty good. If you could expand your budget, I'd advise you get a better graphics card, but if you can't, the build is pretty solid as it is.
If you regard my facts as wrong, feel free to rectify it.
If you regard my opinions as wrong, feel free to ignore it.
Thanks, What would you consider to be the best alternative for the Graphics card?
A 280X. Or a 770. Both are excellent choices but are well out of your current budget.
Original build
New
To be blunt, what I recommended is better.
