What exactly is ghosting?
So im going to buy an Xbox one S, wich i want to hook up to my semi-old Philips 1080p TV. When someone told me i should use a monitor or buy a new 4k TV because " Ghosting " can accur while gaming on a old TV. I asked him wtf ghosting even is and i got a vague response, and when i try to google what it means i get some weird paranormal shit lol.. Would be great if someone told me what Ghosting actually is and if i really need to get rid of my old TV..
https://linustechtips.com/topic/977586-what-exactly-is-ghosting/
Think of ghosting as an artifact that basically means that information from a previous frame(s) is on screen with the current frame (just not as visible), creating said "ghosting" effect.
If you dont notice anything wrong when watching TV shows with the old TV, then either the TV doesnt have ghosting problems or it's just not a problem to your eyes.
Ghosting is a smear on the image caused by the pixels not keeping up with the speed needed to change colour and brightness, leading to inaccurate colours. Imagine yourself looking at a strong light source, then turn around to look at something of normal brightness. Congrats, now you've got ghosting on your eyeballs.
Desktop benching:
It's an unintended trailing of an image in motion. You'll know it when you see it, especially if severe enough.
Ghosting is caused by slow pixel response. LCD technology suffers from this, VA panels the most, which are found in most TV's.
The UFO image gives you a good example of what it is.
Bassicaly when a pixel changes color, it takes a certain amount of time, if it is slow it will show on screen in the form of a trail on a moving object.
This is most noticable in dark scenes.
A very easy way to test this is to simply set a PC desktop background to a dark grey, and drag a lighter gray objective around the screen. The reason this shows up ghosting the most is becouse pixels take longer to transition from a darker color to an even darker color, vs a very light color to a slightly less light color, so in light scenes you wont notice it much if at all. You will see most reviewers who test pixel response display both a 80% transtion speed, and a 100% transition pseed, and these 2 speeds will be significasntly different as the 80% to 100% transition si the slowest. I.e A white to a black pixel transition, the white will darken greyer and greyer down to 80% of the total transition faster than the 80% to %100 transition which is effectivly a dark grey to black transition.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
