Howdy
I was moving some stuff around for my sig rig server, is there any large detrimental reason to not install ESXi on the base/bulk main RAID array storage and instead use a separate medium such as dedicated drive or USB?  I only really planned on slicing space out of the array for VMs and having a container that does Samba with the lion's share of the array space.
The installation size for the hypervisor is pretty small, I was just going to yolo roll it on the same array but it seems like a lot of people keep them separated.
Thanks!
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/977563-esxi-and-installation-volume/
Its easier to move the install around and read the storage if your boot volume is seprate. It also allows for easier os upgrades.
Id personally put it on a usb or sd card as it makes it easier to manage and isn't more complicated, but it won't cause problems not to. One reason why lots of large companies do it this way is because there using network storage and a usb is cheaper than a basic hdd or ssd or there running a hyper converged system that can't be booted off the shared drive.
I don't have experience with ESXi but looking at it from any other server OS type perspective revolving around storage or virtualization the separation of the boot drive from the array makes for what I would see as simpler setup, easier modularity (if you want to move the OS to a different system), or if you want to do something with an array that involves transplanting it into another server keeping the OS separate just simplifies things.
From the perspective of recovery and lets say we installed it on the RAID. If ESXi crashed and refused to work but the VMs and storage data on the array was fine how easily would booting from another disk with ESXi see the VM and storage data on the failed ESXi installation without that failed install interfering with the recovery itself?
Since these OS's can boot off thumb drives I see no reason not to keep that system.
Good points, thanks dudes.  I usually roll a small SSD or something but haven't encountered too many disaster type of incidents, granted I don't do this type of work in any significant volume.
I appreciate the input.
Neither have I, I don't do this as an occupation either. The only incidents I've encountered were a result of human error. The recovery situation might be rare otherwise but when it happens and you see something is interfering with it you may see ways to implement preventative measurements to make the next time around easier on yourself. What we discussed is one of them.
Don't mention it. That's why we're here.
Installing ESXi to USB or SDCard is the recommended setup, then just configure your logging to go to the VMFS Datastore on the raid.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
It used to be you couldn't use the boot media as a datastore, but I've seen lately you are given the option to do so. Really if you lose your ESXI installation it isn't a big deal to re-install and add back the inventory, so I don't see any concerns. Even if it is part of vcenter and it up and dies, not too time consuming to remove it from inventory, rebuild, and add it back. Probably the only headache is if you have multiple vswitches and trying to recreate them and re-assign the VMs to the vswitches (I believe you can export your vswitch config pretty easily).
Have killed a couple USB thumb drives and have had to rebuild a handful of times, never really bothered me.
