I'm building my first computer and i choose those pieces:
asus z170-pro gaming
intel core i5-6600k
noctua nh-d15
corsair 650w
corsair vengeance lpx 16go (4x4go) ddr4 3000mhz
ssd   500gb
nvidia gtx980 ti 4gb
and i think Asus Maximus VIII Extreme  i better
and any auther good chooce about the pieces
so any information please...!!!!!!!!
https://linustechtips.com/topic/977120-build-my-first-pc/
Its outdated and not worth your money unless you can get a really good deal on used parts.
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800716
2 minutes ago, ah med said:
hi my pc is so old i use pentuim 4  :'(
Okay... gives you no reason to buy outdated parts unless you can get them for a deal. As I stated above.
Also, press the reply button so we get notified when you reply to comments
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800731
intel core i5-6600k
noctua nh-d15
corsair 650w
ssd   500gb
whats your budget?
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800736
PCPartPicker part list: https://pcpartpicker.com/list/KZRsjy
Price breakdown by merchant: https://pcpartpicker.com/list/KZRsjy/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($100.99 @ Amazon)
Motherboard: MSI - X470 GAMING PRO CARBON ATX AM4 Motherboard  ($174.99 @ Amazon)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB FTW2 GAMING iCX Video Card  ($429.99 @ Amazon)
Case: Fractal Design - Define C TG ATX Mid Tower Case  ($90.69 @ Newegg)
Power Supply: EVGA - 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $1157.63
Generated by PCPartPicker 2018-09-28 16:40 EDT-0400
mabye this as a starter (note expensive mobo for better upgradeability (i.e higher wattage CPUs.)
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800741
Yeah this build makes no sense at all. You could get a better PC for the same amount of money.
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($144.89 @ OutletPC)
Storage: Western Digital - Blue 500GB 2.5" Solid State Drive  ($80.99 @ Amazon)
Total: $491.86
Generated by PCPartPicker 2018-09-28 16:41 EDT-0400
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800744
17 minutes ago, ah med said:
Budget/Country, what do you need the PC for, what monitor resolution/refresh rate?
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800761
On 9/28/2018 at 3:43 PM, ah med said:
about 1300$
With $1300 you can get a lot more than an old i5
Also make sure to use this button to reply to people
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800770
1 minute ago, ah med said:
thanks
i use this site to the first time
Total: $1157.63
I think Firewrath is probably about right for that budget BTW.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800784
https://pcpartpicker.com/list/qFG33b
I used a placeholder cooler and no graphics card, those are up to you, but for your budget, this is a lot better.
Primary PC:
PSU tier list
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800792
for design and play game
Photoshop, CAD, or 3D work?
Best value is probably an R5 2600 + RX 570/580
Don't need much more if it's only 1080p 60hz
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800800
what is the best piece you can chooce
for me
Assuming US dollars
Primary PC:
PSU tier list
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800804
Something like this would be pretty solid.
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($309.99 @ Amazon)
CPU Cooler: be quiet! - Pure Rock Slim 35.1 CFM CPU Cooler  ($27.89 @ OutletPC)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($100.11 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($89.85 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.49 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($439.99 @ Newegg)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($52.00 @ Newegg)
Total: $1268.30
Generated by PCPartPicker 2018-09-28 17:02 EDT-0400
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800821
Just now, Firewrath9 said:
8600k Overpriced, shitty cooler.
Cooler is placeholder, Op Was looking at a noctuas cooler earlier. Also, no GPU, that's up to OP as well
Primary PC:
PSU tier list
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800822
5 minutes ago, ah med said:
good thanks
PCPartPicker part list: https://pcpartpicker.com/list/Dk9Ttg
Price breakdown by merchant: https://pcpartpicker.com/list/Dk9Ttg/by_merchant/
Motherboard: Gigabyte - X470 AORUS GAMING 5 WIFI ATX AM4 Motherboard  ($159.99 @ Amazon)
Storage: ADATA - XPG SX8200 480GB M.2-2280 Solid State Drive  ($109.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Case: Phanteks - Eclipse P350X (Black) ATX Mid Tower Case  ($59.99 @ Newegg)
Total: $1281.91
Generated by PCPartPicker 2018-09-28 17:04 EDT-0400
good mobo for upgradeability
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800831
Total: $1281.91
That seems like a lot to pay for the cooler for not that much benefit. Also could save on the mobo and grab a 1080. PSU could be better.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/977120-build-my-first-pc/#findComment-11800833
