Hello all,
I was wondering as to which of these are better: DDR4 2400 CAS 10, or DDR4 3200 CAS 14? If I understand the formula correctly, a first would have an effective score of 240, whereas the latter would be at 229? Can anyone verify this? Price and quality are roughly the same.
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/
Depends on the situation. The 2400MHz kit has shorter latency, but 3200MHz has higher transfer rate. It really depends on the workload it's working on.
That said, I expect 2400MHz CL10 to do 3200MHz CL16 easily, as long as the motherboard supports that.
Desktop benching:
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11796710
5 minutes ago, Sakkura said:
The second kit has 33% more bandwidth and 5% higher CAS latency. It will depend on the situation which provides better performance, but in general I'd go with the second kit.
Primarily gaming, but also some computational work and editing. In any given situation, will the RAM make much of a difference anyways?
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11796716
It also depends on your other hardware. Like if it's a Ryzen system, then 3200 is definitely the way to go. On Intel there shouldn't be much difference in most games.
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11796977
Red team so yea ok then. 3200/14. Thanks for the help all
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11798000
8 hours ago, BSula99 said:
Hello all,
If that first kit does that speed and timing at 1.2V then it might be prime for overclocking.  But I am assuming that second kit is b-die and Ryzen loves b-die so I would point you at that one.  Don't want to recommend a kit on the hopes you can get it to 3200MHz with tight timings.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11798098
Hello all,
speed is usually better, i'd take the 2nd kit in this case, after 3600 it doesn't matter too much unless you are going for max oc on ur cpu, say 5.2 or 5.3 ghz on a 8700k.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/976689-ddr4-speed-vs-cas/#findComment-11798123
