Razer Phone cycles between not charging and charging when at 100%
7 minutes ago, voiha said:I am with 8.1 too Nokia 7 plus, and I have kinda the same symptoms.
I guess it's Android fault rather than the hardware itself, sometimes when It's plugged in reaches 100% and after some hours that I left it with the charging cable inside it shows 98%.
There should not be any problem with your hardware, I hope it will be fixed with the Android 9.
Either that or maybe your charging cable wiggles ?
But yours just soudns like standard trickle charging
19 minutes ago, Renton577 said:So I have a Razer Phone and I have this issue when it's plugged in through the night it will periodically make the charging sound like it was unplugged and then plugged back in but only for a second. The phone stays at 100% and works fine in the morning. I just wanted to see if this was a software bug or at least make sure it's not causing damage. It's running Android 8.1.
Your charger may be defective, trickle charging isnt supposed to make the phone go beep when it reaches 100%
