pipe and zipties 2.0
ShadyHost
I've posted my old build on here before. After tinkering with a new idea, I built it last weekend.
Here's something you should never do: suspend a PC mid-air using only zip ties and pipe.
Photos and a video below.
Roast me.
That's actually a really cool idea, it reminds me a bit of InWin's D-Frame mixed with that one ITX Phanteks case.
A full mod around this idea would be really cool to see.
Just now, seoz said:
I officially award you the Balls of Steel award for using a Hyper 212 in this ghetto case build.
Hyper 212 is all you need!
lol
i like it!
if you ever end up making a new model maybe it would be a cool idea to run the tubing through the pipes
Recent build: Fractal Design - Torrent reviewMeshify C / The 1080TI Strix Noctua modDefine S X58 Xeon build  / Specs: i7-14700KF 5.8Ghz - ASUS TUF RTX 4080 super - G.Skill Ripjaws 32GB 4000mhz CL18 -  Gigabyte Z690 Gaming X d4 - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua D15
6 hours ago, BadMonkey said:
Change zipties to paracord
I like that idea.
If I take it apart any time soon, I may paint the tubes black or some other color to clean up the look and figure out something else to hold up the GPU
I wonder if paracord stretches with heat?
I guess the most difficult thing, with a build like that, would be plugging things in.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
4 hours ago, CUDAcores89 said:
Case made out of PVC pipe and Zip ties but has custom water cooling...
priorities...
This wouls actually work really well if you skipped the zip-ties and simply drilled and added threaded inserts to support a motherboard. Then you add a PCIe bracket for the PVC pipe case and voila, you have an open-concept style case.
It's that cheap EK aluminum kit.
CPU is an 8700k
and the GPU is a 1080ti
I think the total materials cost was around $10
I spent more on the pipe cutters lol
